So I'm taking my time doing my front hub seals and I want to address all the little problems now before I button up my drum again.
Some questions,
1. From this picture can you tell me if I have the 10" or 11" front drums?
2. If you note the pitting on the stub axle, is this a problem? I don't think it is on the race at all.
3. When I reinstall the felt washer, does the rubber side face inward or outward? My old one I took out ripped in two and seemed to have rubber on both sides. My replacements only have rubbber on one side.
Other than that, I think I've gotten off lucky! The bearings look great and the race seems smooth, (the picture looks worse than it does to the naked eye). So, I'll degrease the backing plate and drum, replace the brake shoes, repack the bearings, install the new hub seal, pull-in two wheel studs and then button that drum up and move on to the other side after a victory lap around the block! :drive:
Let me know if I'm forgetting something please and thanks.
Some questions,
