My Range Rover has an odd problem. It always starts ok but it will occasionally (intermittently and randomly) begin cutting out and stumble and act as if it's running out of gas or has a loose ignition connection. When the problem occurs, it will never actually stall out completely since it will return to idle fine but once I apply any throttle, thats when the problems are really noticed! Sometimes if I floor the throttle through the symptoms, after a little while...with some popping and minor backfiring up through the air cleaner, it seem to help it go back to normal eventually. If I pull over and shut down, it always restarts ok, but the problem is usually still there up until it runs its course and then just goes away as suddenly as it began! I am not sure what triggers this and the fact that it comes and goes randomly is a mystery! I think it must be electrical, possibly distributor related. I have checked everything visibly on the engine and nothing seems noticeably apparent and all is connected. The fuel pump had been replaced recently by the previous owner. I imagine the fuel filter had been replaced at that time as well(?) Does this sound like a fuel issue? Possibly a relay going bad? Has anyone else experienced this before? Please help! I have a complete Range Rover factory shop manual on CD up for grabs for someone who can help me through with this until it's fixed! :drink1:
