1992 Range Rover Classic SWB Aspen Silver
3.9l EFI
Borg Warner transfer box
ZF Automatic transmission
Full-time 4WD w/ 3.54 gears
165k miles
View image at http://www.get-rhino.com/srangie/IM001518.JPG
This RRC has been our run around town vehicle. It’s a good solid truck but does need several little things repaired on it to be back in tip top shape. We are starting on a 110 project and do not have the luxury of a spare vehicle right now. Below is a detailed list of the parts recently replaced and things needed to be repaired. The truck has very little rust on it and the usual spots like the floor boards, sills, back lift gate etc…are in fine shape. The interior of the truck has been Rhino lined for protection it has carpet & mud mats along with front and rear water proof seat covers. The truck also has a 2” body lift but still needs the correct radiator spacers and seat belt extenders installed. [Order from Red Rhino Products] It also has a Brownchurch roof rack w/ 4 lights [They need wired and one is damaged.] At one time it had a snorkel fitted and there is a hole in the front for it. All the windows work well. It is fitted with genuine wheels and 34x10.50 LTB Swampers which will need replaced soon. Asking $3500 obo.
Recently replaced:
Plugs & wires
Distributor & rotor arm
Ignition amplifier module
Fuel pump & assembly
14CUX ECU w/ 4.0 chip & 5AM MAS
Fuel filter
Coil [Genuine Lucas]
Complete Genuine transmission service
All other fluids renewed
Complete steering shaft assembly
All engine belts
Alternator & battery
OME HD front & rear shocks
Bearmach 3” HD spring front & rear
Front Cardin style driveshaft
Rear driveshaft u-joints
Needs Repair:
Seat belts
Sun roof motor
Headliner installed
Electric seat controls
Front left caliper hangs sometimes
Coolant temperature sensor
Washer fluid sensor
Back tail gate latch is hard to open sometimes
Needs new lower door speakers
The fuel pump wiring harness worked intermittently so we wired it to switch
Power steering pump leaks [The norm for these trucks]
The rear bumper has been cut
Door lock electronic actuators
Email [email protected] for more information.
View the rest of the ad at http://www.get-rhino.com Click on [Vehicles For Sale] on the main page.
Thanks for the space!
3.9l EFI
165k miles
Recently replaced:
Plugs & wires
Fuel filter
All engine belts
Needs Repair:
Seat belts
Sun roof motor
Headliner installed
Washer fluid sensor
