This is really a continuation of my running-like-crap-on-the-highway saga, but the plugs are the ONLY thing I haven't changed in the last 20k miles. I checked all connections, and what baffles me is that it starts up just fine, and although at the tailpipe it SOUNDS like it's missing on one cyl, when I move to the engine bay, it sounds smooth. I'm taking the exhaust note as a false indicator.
Revs freely at idle, but it's beginning to "miss" at other lower speeds on acceleration, and DEFINITELY at 60-65 at light throttle. When I move up to near 70 mph, it seems to clear out, and also if I downshift and let the engine rev @ 2500 and above. Runs cleanly then.
Because of the smooth-ish idle, I have NOT put a timing light on each plug wire yet. The one thing I HAVEN'T done in the last 20k miles is CHANGE the plugs. When I checked 20k miles ago, each was burning picture-perfect cleanly.
But if one (or more) has now opened up a gap that is excessive, MIGHT that cause a mis-fire @ low rpm?
At 169k miles, is the OEM-spec plug still the best, or is there a preferred alternate?
