Disco Mike, please call if you have a moment, 303 435-1168
need help trouble-shooting
Symptoms:
-no brakes when pushing pedal, little at best
-ABS pump runs constantly; spongy pedal
-fluid level dropped and raised in reservoir when applying brakes after replacing parts; not sure if still occurring since power bleeding and replacing parts a second time.
Parts Replaced with used parts from working '95 parts cars;
-ABS block (suspected crack)
-accumulator
-ABS pump
-cleaned ABS relays
-ABS ECU seems to be working
-power bled several times
Cannot find an air leak; short of replacing all the above with new parts, any suggestion on where to start?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
