98 D1 overheating again...need help
My Disco is overheating again. In February I replaced the radiator, thermostat and one of the electric A/C fans. Today, I noticed the tempature climbing as I was idling for about 15 minutes with the full A/C on. I checked the electric fans and only 1 (the one I replaced the closest to the drivers side) was running. So I have a few questions:
1) Should both electric fans run together? I assume so and I am guessing I need to replace the one that's not working but I would like confirmation.
2) How can I be sure the thermocouple (the main fan driven by the engine with the viscous clutch) fan is working? I know they sometimes go bad but I don't know how to test if it is working properly. It is always spinning but I can't tell if it is engaging or not.
3) I don't have any squeks or leaks for the water pump so can I assume it is OK?
Thanks!
Phil
Thanks!
Phil
