1 - 2 of 2 Posts
Hello all
Got a problem with my RRC that some of you might have encountered.
There is a noise that seems to be coming from the rear diff, a loud semi vibrating resonant scratching noise; If you were to take two metal cooking pots and clamp them together and rotate counter in a housing (under load). First i suspeced the transfer case but i dont think it can resonate that much.
One of the rear wheels can rotate almost 2" (measured on the outer tire) before the other spins so that is probably an indicator that the diff gears are worn.. i dont know since i havent worked that much on these cars.
There is no gripping and chirping in turns by the way so the viscous coupling seems ok.
Any help would be appriciated.
1 - 2 of 2 Posts
