Found myself without a running 4x4 for the Nevada winter, not good.
From January to April the weather will be cold and the roads slick.
Found a '96 Disco on the cheap, pretty high miles at around 200K but the price was "too good to pass up".
It sort of runs, but is very low on power.
I've had my Series 2A 88" for decades and will definitely restore it again.
The 88" 2.3 would run circles around this Disco!
Previous owner replaced the upstream 02 sensors, I just replaced the downstream 02's.
Fewer codes now but still getting Early Ignition Coil Activation Fault Coil 3, P1374.
Early Ignition Coil Activation Fault Coil 4, P1375.
I suppose it's nice to have these codes, but they are not well defined.
Early Ignition Coil Activation Fault = WHAT exactly?
"Early" would seem to indicate premature, but really gives no clue to how or why.
This same fault on two of four coils.
Anyone able to clarify what I'm really looking for from here?
In poking around the web I see several Rovers with the coil packs relocated to the front of the engine, any real trick or downside to doing that?
Another issue is that it keeps blowing the 15A fuse for the fuel pump.
Also have the "Service Engine" and Seatbelt system lights on constantly.
Oh, and the tach is pretty erratic too.
Not looking to restore this one, just need to be able to use it for a few months until I can get an OLDER model up and running.
I have some very trick diagnostic equipment I would be able to use if this Disco just had an actual distributor, but no way to connect with this type of ignition.
