1 - 6 of 6 Posts
This is my second range. Problem is if I don't press the button to lower it to the lowest setting it will sit low on the drivers side and high on the passenger side, this is only when the truck is parked for a period of time not while driving. Just wondering what would cause this or if anyone has has a similar experience. Thanks
Former LR tech, Albany NY
take a bottle and fill it with soapy water. Then spray them down and you should see them bubble out.
Trust me its an gas trick you use after installing natural gas pipes as well.
1 - 6 of 6 Posts
