Make sure the air suspension has been replaced, that's an easy 4 to 5k to replace. (very common problem on that model). the BECM is another problem with that model. thats also costly....have a mechanic look at it!!!!, check for oil leaks and head gaskets leaking....you should save your money for a better truck with lower miles. that's my .02....
either way, good luck
