So I had major problems getting the fuel filter changed on my 97 disco. It was the original filter and the internal parts were loose and the fittings were completely rusted and stuck on. Yes I tried ever trick I could think of. Minus heating the bolts with a torch. I like to live.
So I had to cut the hoses (as close the to filter as I could) holding the fittings that screwed to the filter. Leave a lot on the vehicle.
To fix this I had to get a wix premium filter #33252. It's about $33!! Then two 1/4 inch barbs with thread fittings on one end and 2 female to male fittings to fit from the barb thread to the filter threads. I got them from oriellys air tool section. Needs to be brass fittings. Two hose clamps to fit the 1/2 inch. outside diameter hoses.
When you put all the fittings on make they are TIGHT or fuel will leak!!! Make sure you note which way the flow arrow points cause if you get fuel on the arrow marking it will wash right off!!!
