OK, so I purchased the following from Rovertym:
2" RTE Springs
Front Springs (Heavy Duty)-RR3
Rear Springs (Medium Duty)-RR4
OME Shocks
Front Shocks (Heavy Duty)-N115
Rear Shocks (Medium Duty)-N46
Steering Stabilizer-SD11
I decided to go "heavy duty" in the front because of the Rovertym bull bar, Warn 9000, and a skid plate. I ran all of this past the saleman on the phone and he agreed with choices.
A buddy and I put the suspension on and found that the front suspension ended up being a lot higher than the rear. It's almost as if the rear was not lifted (or very little at all) and the front had 3-4 inches of lift.
What's the deal with this?
Also, upon removing the front springs we found that the two were not even identical. One spring had less coils and was about 1 1/2 inches smaller than the other...???
The disco has approx. 120K miles. I noticed significant vibration coming from the rotoflex driveshaft - I'm guessing I need to do some mods down here to stop the vibrating?
What do you guys think???
2" RTE Springs
OME Shocks
