I bought a 97 se7 that the key switch was bad and was starting with a screwdriver. I want to put in a aftermarket key switch, but I have a question about the wiring. I found the wire that I believe is the acc(first notch), however I have 2 wires that energize in the run position(second notch). My question is can I put both wires under the same lug on the new switch?
