1 - 1 of 1 Posts
Land Rover Discovery II Expedition Equipped​
This Disco 2 is mechanically sound strong smooth running engine, trans shifts smoothly and transfer case works perfect. All windows, sunroofs and door locks work, A/C works perfect, OEM radio and CD changer. I am the second owner got her with 50k on 2003. I change the oil every 3k using mobil 1 Full Synthetic, Trans has Valvoline Max Life ATF(30K Interval), Diffs and Transfer case are filled with Mobil 1 Synthetic Gear Lube(30k Interval). I replaced the headgaskets at 150k with the updated composite ones, heads were cleaned and decked new valve seals and guides I also replaced the water pump and thermostat at that time. So far 30k plus miles no problem. Body and paint are in ok shape some dings and dents I do use it for overlanding. Interior is ok seats are cracked I have covers in the front, headliner is 3 yrs old and in great shape. I replaced the cracked grab handles with MIL Spec Paracord ones.
Upgrades
Suspension: Old Man Emu HD Springs, Shocks and Steering Dampner
Wheels and Tires: Pro-Comp Steel Wheels and Treadwright Mud Terrains
Front bumper: Tactical Rovers
2004 Diff Lock shifter kit
Snorkel with Cobra Head and Pre-Filter Bowl included
Limb Raisers
Electrical: Headlights and Fog lights are H.I.D, USB chargers Front and rear. 100amp Circuit breaker for cargo accessories. Cobra CB
Expedition Equipment Included
Recovery Kit On Board Air Compressor 150psi
1500 Watt Inverter On Demand 9Gal Water Tank(Hose Kit Included
The rear bumper is cracked on the drivers side, but still functions as designed.
A steel rear bumper would be a nice upgrade. The plastic rocker cover is broken on the passenger side. Of course there are scratches and dents, paint is in good condition. I described this vehicle as best as possible please feel free to ask me any questions.
Florida vehicle absolutely no rust, clean title on hand.
Located 20 min north of Tampa, Fl
$4,500 O.B.O
1 - 1 of 1 Posts
