1 - 5 of 5 Posts
I heard a rumor that you cannot make them come on, that they wash only about every three or so times that you turn on the windshield washers.
Can this be right? Or is there a way to turn them on???
Need more info. Headlights on and then what - they come on automatically every three times? Or what? Do not think they work every time you use the wipers with the lights on. May go outside and check.
certified idiot
yes - every 3rd wash of the windshield the headlight jets will run too
cheers
Barri
Discussion Starter · #5 · (Edited)
Thanks. Every third time. I just tested it five times and it does not work at all. Is there a fuse that might be blown? Other than looking to see that the rubber line is still hooked up, what do I look for?
Good info. Thx.
I found the fuse. Inside cabin fusebox, Satellite C which is the set of fuses at the bottom of the fuse box. It is fuse #2 which is 20 amp. Need to go outside and take a look.
Good old Mr. Google.
Well, do not believe everything you read in Google. The fuse turned out to be under the hood and it was not blown. Not sure what to do now.
1 - 5 of 5 Posts
