Hopefully going to be turning this into a build thread!
Parts ordered from Atlantic British, I found it hard to justify $7700 on a new engine setup from them, and TWS motors was somewhere in the $12,000 range for a similar setup but with a 300hp rating. Needless to say I am officially doing it myself.
Parts from AB include all the new engine goodies, plus a new oil pan, piston and connecting rod.
Turner in the UK will be providing their street cam.
Q&E machine shop in LA will be decking the block and heads, and putting in flanged and O ringed sleeves from LA sleeves. They will also be port and polishing the heads, and grinding and balancing the crank to .020.
I plan to send in my flywheel to TWS to get it lightened by about 10lbs which is cheaper than a new one.
And lastly I’ll be sending off the ECU to Tornado in the UK for a flash, mostly due to TWS wanting roughly double for the same thing.
All that put together should make for a highly reliable engine build for the next 200k+ miles, and add some much needed torque and hp in the 3k and 5k+ RPM range. Couple that with less rotating weight from the flywheel and crankshaft, and this should be an engine that really has some good power.
