I’m going to leave this here since there is NO info on it online.
For removing the ECM (or ECU, same thing but manual lists it as ECM), here are the steps.
For the purposes of showing you all where it is, it is on the passenger side, behind the glove box. The manual says to lower the glove box as you see above. But this isn’t necessary. It’s much easier to get to below the glove box by removing the bottom trim panel, and then the right hand side panel. But again, this will help show you where it is.
Looking through the glove box, you’ll see a silver box mounted on the right hand side firewall. That’s your ECM. The second picture above is the ECM from below with the bottom trim removed, but the side trim still in place. The side trim covers the connectors and therefore needs to be removed.
And there she is. Now remove the four connectors on the rear. The leftmost and right most connectors are push button. The middle three you unclip as follows:
First push this button to release the lever
Lower the lever
Lower lever all the way and the connector pops right out.
And here are all the connectors in order of how they came out. They only go in one spot, so it’s dummy proof, but just in case anyone needs the info.
And there it is out. Now it’s off to Tornado in the UK for a reflash! Hopefully this helps someone, somewhere, someday!
Lower the lever
