1 - 5 of 5 Posts
Anyone ever have a problem running there AC then stall and car not start? I have an 03 disco2 se then when trying to start the two green gear lights flash anyone know what that's about? Started after being cool.
· Premium Member
Do you have any fault codes if so get the fault code numbers, then go to a local parts store and get a free charging system test done, voltage should be between 13.6 and 14.4 volts then get back to us.
Ill get codes tomorrow
Thanks mike ill get codes tomorrow. But everything has been fine up until using my AC battery is new and car started after trany cooled off its like I was overheating but wasent. The two green gear lights on dash were blinking when key was on.
· Premium Member
Which can be an indication of a low battery or failing alternator.
1 - 5 of 5 Posts
