I need some help..please!
I parked my truck (2001 Disco SE7 ...58K miles) after a 300 hundred mile trip.
Today when I tried turned on the A/C it would not work.
In detail: I turn on the A/C switch and the interface panel lights up. All the controls responds. That is to say the fan speed shows increments of speed and the "economy" button responds..however the BLOWER DOES NOT BLOW.
The AC Compressor also responds when the switch is turned on or off.....it just DOES NOT BLOW any air. The problem is also affecting the rear air..it too does not blow.
I checked two FUSES under the dash (per the panel markings). The fuses read good. I also checked one fuse under the hood...this too was good.
I see what appears to be an associated RELAY. I have not been able to check this.
Has anyone had a similar experience...and if so what was the solution?
Much appreciated.
Hugh
May we all live healthily in 2006 ( I mean...beyond as well)
Much appreciated.
Hugh
