AC Recharge ports not labelled "High" or "Low"
This information is correct for the US model; the high side is just inside the 6 cylinder gas engine by the firewall, the low side is inside the compartment, both on the passenger side. Both are labelled "MAX 6 Nm", not "High" or "Low".
Note: to place the Recharge gauge on the low side port you will need to partially remove the plastic shroud with a phillips screwdriver.
