Hello all,
Being of the worrying nature where my pride-and-joy is concerned, I'd like a check on this.
How much smoke should a 2.25 diesel produce when in good condition and everything set up right?
When you start from cold (which it does after just a few turns after 10 seconds pre-heating) you get a puff of blue smoke, followed by a puff of black, neither of which are what I'd call excessive. You get a haze of blue on acceleration as the engine warms up. When warm, if you blip the throttle from idle, a hazy black cloud puffs out the exhaust- not the solid black smokescreen you get from really knackered diesels. I know that an old indirect injection diesel will smoke a bit on acceleration, but how much. Are we talking small puff, or thin cloud? (like what I'm getting).
On the road, I adjusted the wing mirror to point at the exhaust. There's nothing when holding a steady speed. As you accelerate, as the engine takes up the load when you change gear, you get a faint haze of black that lasts about 5 seconds until the revs build up.
I know not to expect: a) smoke-free engines (it is a 1956 design, after all)
b) serious problem (believe me, I've seen the engine when it's knackered and it was about 100x worse than it is now)
I just want a check in case something needed adusting post-rebuild/run in, such as tappet clearances.
Any thoughts welcome, as I no longer know anyone with a diesel Series Landy to compare it to.
Jack (needlessly worrying SIII owner)
