1 - 2 of 2 Posts
I have done option B few years ago. worked for a while but keep coming back.
Now I have the 3 Amigos and the Brake light on Permanently. Can't erase with USB Amigo or other scanner. Time to time the Pump will come on for no reason while driving but does not do anything.
I went ahead and bought a used pump. Do not know if that is any good. But I am willing put in to see what happens. Any advise how to swap and bleed the Pump?
Current fault code is
1.--Current Faults---->
Active Faults:
012:pump fail monitor line
Logged Faults:
Here is the explanation -
http://www.rswsolutions.com/index.php/discovery-ii-abs-codes/63-012pump-fail-monitor-line
2001 Discovery II, BMW Z4, BMW E60
After you refilled the system first pedal bleed it in the right sequence(from the shortest to longest line) then if you have tester power bleed it or if not find a hill and make the HDC work hard then pedal bleed again and top up reservoir ...it will bleed itself this way
1 - 2 of 2 Posts
