1 - 2 of 2 Posts
Had the dreaded brake, abs and tc lights come on in my 95 classic LWB. Was able to research the codes and tapped the front left sensor . Codes where then cleared. Thought all was well as I took the beast for a ride. When I got back home and switched off the ignition and the abs pump kept running. I had to disconnect the battery to switch it off. After more research I replaced the abs relay under the drivers seat, but this did not. Switch the pump off! Now what? Bad ABS pump?
1 - 2 of 2 Posts
