1 - 6 of 6 Posts
Hey guys,
A while back my AC just stopped working.. No fan No AC.. but i do get the minimum amount of heat when i pull the bar over to full red. Anyway I have been dealing with it for a while ( super busy lately ) I figured it was just a relay in the passenger side foot well.
Well i swapped out all of the relays with the same color ones in there and Still I have NO AC.. Am I pulling the wrong relays??
93 LWB..
Thanks in advance
· LRO Founder
welcome to my world... EXACT same problem I have on my 1995 since about 3 weeks ago.... aaarrgghhhh
Serg
Ok Got Sideye to give me some quick advise
He said to bypass pressure switch at accumulator and see if it starts up. Supposedly thats the most common fault .. a low a/c charge.
Ok ill try it..
· LRO Founder
oh.... no I meant my fan won't turn on even without the A/C.... aarrrghhhh, has to be a bad ground somewhere...the blower motors are fine, the switch is fine, all the fuses, relays are fine... oh well..
Serg
The A/C doesn't work in my 1995 P38. i don't hear the compressor click on, but can i run this check too and see if low or no freon is the problem? Testbook symbol is lit on the display. Or could it be the actual a/c clutch, or the condensor?
1 - 6 of 6 Posts
