1 - 5 of 5 Posts
neither my ac switch and my recirculation switch (or what ever its called the one to the left of the ac switch) is lighting up. Ive checked all the fuses and I cant find any blown. If its low on freon it should still light up right?
Discussion Starter · #4 ·
Ok so I tested the plug on the compressor and I don't have 12 volts. I jumped the compressor and It kicked in and I had cold air. I changed the k108 relay and I checked all the fuses. I also put a NEW ac switch in and still nothing. I pulled the new switch and put 12 volts to it and when I pressed the switch the light came on. SO WHY DO I NOT HAVE POWER TO THE SWITCH NOR THE PLUG?
Discussion Starter · #5 ·
I pulled the ac switch and put an old white plug i got out of the junk yard in the back and tested the switch by putting a 12 volt supply to the plug and pushing in and out and the light came on. By playing with the plug I realized (I think anyway) that wire number one and number three on the plug should be hot. When I energized either of them the orange light on the plug lit up. On the white plug in the car only number 3 is has power. Is my thinking right? I've looked at the rave and I can't find what I'm looking for. Where's my problem? Any help would be greatly appreciated.
1 - 5 of 5 Posts
