1 - 3 of 3 Posts
The ACE Light came on. Tell us not to drive anymore. Called the deal it will not hurt anything just have to deal with the light and the sloppy driving.
I checked and it was very low with fluid, I filled it up took it for a ride came back, checked it was low again, did the same again and it was ok. BUT, there is a leak at the Solid aluminum box under the passenger side where I think all the ACE line tie in. Anyone know where I can get one or if it might just be a seal that can be replaced?????? Please email me at [email protected]
:dunno:
There is a drain plug and a filter on the bottom side of the valve block. I would start there first. Make sure all the lines are thight also. The valve block itself is very exspensive around $700 I think. If the ACE system has been performing normal it is more than likely a seal or hose.
1 - 3 of 3 Posts
