is the aircon THE ONLY thing which is not working?... ignition power supply for the aircon unit comes from fusible link FL8 engine bay fusebox goes through the ignition switch to fuse F31 interior fusebox then to the aircon unit's plug green/pink wire C0791-2...but if FL8 is gone it would affect other things too
let me know when you have the RAVE and i'll tell you where to measure, or you can figure it out yourself cos everything is in there but first of all double check fuse F31 or replace it to be 100% ruled out
