1 - 2 of 2 Posts
Hi!
I'm having some trouble with my RR SC 2007 air suspension. When left for night sometimes it drops to bump stops, sometimes it doesn't. When disconnected from battery it can stays raised for weeks. Already checked for leaks at front valve block and air compressor, but couldn't find any. Also left(driver) side is lower ~1-2cm than right side at any height settings, can this cause the problem? At the moment going to dealership(500km away) is not an option, so I'm hoping for internet diagnostics.
Cheers!
Mark
I would double check for leaks at the compressor, specifically the dryer and its lines. Most common issue with intermittent drop on this is from a valve block sticking open, and leaking through the dryer.
1 - 2 of 2 Posts
