1 - 4 of 4 Posts
Discussion Starter #1
Hello everyone!
I have Land Rover Discovery 3, 2007 year. I had a problem with air suspensions, first I got that yellow indicate " Suspension fault", after diagnostic I was informed that my compressor's valve block is broken, they advised to change compressor.
I changed compressor my self, did everything by you-tube video, but the problem is that Error is still showing "Suspension fault" and compressor is not pumping up car.
Idea is to take car to service, make new diagnostic and delete error, and than maybe its should work.
Does anybody had similar situation or can advise what could be a problem.
very disco
Which codes were pulled?
very disco
Which compressor did you fit and where do you get it? When I rebuilt my EAS, I tried to use a cheap hitachi knockoff. In fact I sent the first one back and tried another. Both threw that code. I bit the bullet and spent the $700 on the AMK compressor and flashed the updated software, and no issue since.
one of the cheap compressors I tried was from million parts. $279 I think I paid. What good is cheap if it doesn’t work?
1 - 4 of 4 Posts
