1 - 3 of 3 Posts
Good afternoon from the beautiful Okanagan Valley in BC, Canada. Bought an LR3 last year, love the drive, but have a few issues. One in that the alarm goes off about five minutes after locking up (no issues with vibration, level etc.). The other is that it will slip out for Drive, into nothing (no gear or engagement) while driving. Any thoughts would be greatly appreciated. Thanks, Mike
Most likely culprit is the hood sensor.. It is a common failure item.. I think it also might have a tip sensor in it.. not really sure, but that is where I would start.
The slipping out of drive issue seems most likely to be a linkage / cable or other hardware issue. Drop me a PM w/email and I'll send you some info on what to look at.
+1 on both, had both issues few years ago.
The hood switch is under the passenger side hood latch, very easy to replace.
My linkage just beside the transmission was corroded, needed some cleaning and lubrication. Better if you can replace but mine still works.
Good luck and keep on learning, those cars like to keep you on your feet :D
1 - 3 of 3 Posts
