So.. a bit of background...
2005 LR3 manual. 2.7tdv6
Had the screeching from EPB module. I knew all the brakes needed an overhaul so decided to fit new rotators, pads and shoes. Along with new handbrake cables, and a gear set for the module..
All went well, handbrake was adjusted correctly and the bedding in sequence done.. Handbrake works perfect, brakes are all good...
On start up I have no warning lights.. but after driving around 500m I bet an Amber brake light come on and stays on... until I restart...
I do know that the rear pad wear sensor is broken, could this cause the handbrake light to illuminate? Or could it be the brake switch ?.. when codes are read there is nothing.
