If it’s not leaky, then something is wrong right?
Well after changing out the water pump I have a new coolant leak. Thought it might be the gasket so I swapped out a second new one. Still leaking. So, I’m about 90% sure I've traced it to the front timing cover.
So this coming weekends fun project will be a full front engine refresh! New oil pump gears, timing chain, gasket, and since I will have to drop the oil pan, a new oil pan gasket as well. Should be fun. More to follow on if it works!
