Clayton,
Make sure you downsize some of those 5.2mp photos before posting on a bbs...
Now, firstoff, get thee a green bible. This is the two volume shop manual that will show you everything you need to know about the rover. This should be available via any of the regular parts houses, Rovers North, Atlantic British, British Pacific etc...also, get to know the other parts houses such as Rovers Down South and the Thatched Roof Garage.
Oof, you bought a vehicle without knowing if the engine spins?! :confused Well, time to find a hand crank and turn her over. I'm assuming you're going to have to rebuild all of the brake/clutch hydraulics, honestly, that's pretty simple stuff, especially with the help of the proper manual.
What I would do in the short term, until you get the manual, is to change out all of the fluids and any hoses that look suspect. As you work through the hydraulic system, check the condition of the lines...it's always easier to change them out now then having to drain the system again. You'll need new or rebuilt wheel cylinders and check your brake shoes for oil contamination...you might need to replace the hub oil seals.
Bogatyr
Bogatyr
