1 - 9 of 9 Posts
Discussion Starter #1
Good evening to all there. Opening this cause didn't find solution for my problem yet..so my ranger is a 87 efi,5dr,lhd..and my problem is the needle of the tachometer is suddenly no longer lit up red.so I checked the bulbs mounted backwards- but all three are fine and light up properly.even the dim for the dashlight works and all auxiliary lighting is fine. So has anyone an idea,why this red needle light is no longer working?
very disco
No answer because answer unknown! If bulb is on but needle isn’t illuminated, I would guess that the needle is suspect. It should illuminate like fiber optic, so if it’s not maybe it’s cracked?
So impatient....
I get it ...lol
But really I have never heard of this kind of problem
Or really noticed the lighted red needle
But I am going to look at it
I also have a spare parts Speedo I can mess with
HI, I have the same impression that dash could be lit brighter than with standard bulbs, so LEDs maybe !?
Additionnally the Revmeter works erratically, and shows less rev than reality (see pic !!) ….
any clue ?? thanks !
If the tach is sporadic and the light dim, I would suspect the alternator. I have a 94 RRC and the tach runs off the alternator. I expect it's the same for the 87.
very disco
What bronzeking said.
1 - 9 of 9 Posts
