So you guys know the story - after a suspension lift, the travel of our panhard bar forces the axle sideways so that it is no longer centered under the body. The bigger the lift, the bigger the problem.
Detail:
Because this condition forces the front radius & panhard bushings to be in a constant state of flex it accelerates wear and decreases ride quality. Given enough time, you'll experience vague steering, clunking, death wobbles, tire wear, etc.
The solution is an adjustable panhard rod that enables you to center your axle to offset the additional lift.
I'm currently building my own. My design is based on taking the OEM tube, removing a 4" section, welding in some threaded ends, and using a "jack screw" to attach and adjust the distance between the two halves.
Here's my inspiration:
My design is slightly different because it uses a "jack screw" instead of a threaded rod. A jack screw has opposing threads and acts as a turnbuckle. Therefore it can be tightened or loosened while the bar is installed, unlike the aftermarket versions which force you to remove the bar, spin the head, and reinstall it.
Jack screw:
Here's a quick model of my design:
The threaded ends are 4130 chromoly and the jack screw and jam nuts are Grade-8 5/8"-18 thread. The welding is gas-shielded MIG using ER80S-D2 wire to ensure the highest possible tensile strength. A beveled weld channel between the threaded insert and rod ensures excellent penetration, with two plug welds on each end for added peace of mind. The unit is then finished using automotive primer & paint (catalyzed paint using HVLP - no rattle can). I wish I could powder coat, but I can't.
My question is - are there any forum members out there that would be interesting in buying this piece if I were to build more than one?
Here's what I'm thinking for pricing:
"Base Bar" (Paint & Primer, NO BUSHINGS) - $125 shipped + $50 CORE
Add OEM Bushings - +$35
I'm an engineer by trade, so this is something that I would make in my spare time. I have a couple of spare bars so there would be no downtime. I'm not looking to make a lot of money, I just wanna have fun and maybe help the community a bit. I'm an experienced hobbyist welder and through my job I have the means to do NDE testing to ensure the strength of the welds.
My particular unit should be done by the end of next week and then Ill update this post with more photos.
Let me know what you guys think - you won't be hurting my feelings if you think it's a stupid idea.
Detail:
Jack screw:
