If you have, can you do me a favour and have a look under the bonnet.
I have just found a vacuum tube come loose that is fitted to the bulk head end of the inlet manifold and goes forward but I cant find where the other end is supposed to go. I have tried working it out buy the length of the tube but with no luck. Its not the vacuum pipe that runs from the front of the inlet manifold to the ecu.
Thanks
Thanks
