1 - 7 of 7 Posts
Drives like an old man
I've got this crazy, probably stupid, idea to buy a cheap thermostat, cut it open and gut it, and replace the junk inside with a real, temperature-operated thermostat. Once reassembled, it would look completely stock and wouldn't require any other cutting or replacing of hoses. Has this been done? Think it's even worth trying?
Administrator
I am pretty sure the "junk inside" is pretty much a normal conventional "temperature operated thermostat . What other type is there?
The main difference is the flow and additional hose running in bypass.
Also I can't imagine cutting the housing open , piecing it back together being anywhere close to reliable.
I would think doing the inline modification would be the most reliable and likely the cheapest way to go
It's my understanding (it's been said many times on this forum) that the thermostat is pressure-operated, not temperature. Freakin' BMW. Never liked their cars. Anyway, I think it would be quite easy to make this mod and install a hi-flow thermostat in place of whatever piece of crap Motorad put in there. I think I have a spare, so maybe this weekend I'll give it a try. If this works, it'll be lots cheaper and easier than the inline mod. A simple medium-temp adhesive will hold things together.
The thermostat has two parts within, the temperature operated valve and a pressure sensitive one for bypass... see attachment then maybe you'll reconsider your plan
btw it's Rover not BMW
Discussion Starter · #5 ·
It's BMW. They designed the POS cooling system. I don't need my car to warm up quickly. I need it to cool down quickly. So, really, I need a high-flow thermostat that is actually wide open at 180, not just beginning to open at 180. I'm pretty sure the thermostat is the source of the problem; this will either confirm or reject that theory.
Have you not seen any of the threads pertaining to the inline thermostat modification? If you want lower, consistent coolant temperature do a search on it. Your idea isn't going to work. You want this:
Discussion Starter · #7 ·
Okay. Everyone says it's a dumb idea or won't work, so I'll take your word for it. I still think it'd work but I can't get my temps over 107 no matter what I do, so I guess I won't bother. Unless I get to a point where I literally have nothing to do, I'll just let it go.
1 - 7 of 7 Posts
