1 - 4 of 4 Posts
Is anyone using an aftermarket head unit with the Harman/Kardon amp and speakers? I have a 99' Series II Disco and Crutchfield says they have a harness that will allow you to retain the Harman/Kardon setup and just replace the head unit. I'm thinking of doing this because I don't want to spend the $$$ for the factory CD changer and this way I will have a CD/MP3/WMA player and also an aux input for sat radio for later down the road. If I wanted then I could even use a CD changer later too, plus I don't have to figure how to make the factory sub work with an aftermarket unit.
Super Moderator
The thing is, you'll loose the functionality of the steerign wheel stereo controls.. Is it worth it?
Ive found a ton of different steering wheel control adapters that might work. havn't tried one myself yet because i have the same problem with my '02 freelander. i want to put in a new head unit but dont want to loose my HK amp and cd changer. no solutions yet.
Yes i have done it in my 99 land rover discovery 2 all you need are the factory removal keys and a PAC-OEM 2 also a dash kit its a small plastic black piece that fills in the gap i put in a Indash 7" touchscreen dvd/tv/cd also i cut my factory radio wiring harness becaues i will never use the origanal land rover radio again heres what i went buy i never used the blu green yellow cable thats data lines and cd changer if you need any help PM me Answer
1 - 4 of 4 Posts
