Hello,
I have finally got my '87 Range Rover Vogue on the road after a year of repairs and am discovering its quirks and clunks.
I want to change the transmission oil and filter (ZF 4 speed) as it is not as pink as it could be. It does not smell burnt but I have a 1st gear/reverse gear clunk (worse when warm)
The car has 50K miles so may not have ever had its gearbox oil changed in nearly twenty years!
My Haynes manual says 'drain oil, remove sump, change filter bolt back together...etc'
Do I need to remove the chassis member to remove the sump, or can I wriggle it out around the exhaust as well? I have heard horror stories of having to spread the chassis legs etc....
Mr Haynes makes it look easy! Do I need to plan ahead for any surprises?
Many thanks in advance for your suggestions (great forum btw)
