its not a tail light guard....lol...go to Atlanticbritish.com and type in axle protector under discovery and it should be up thereHank said:Thats a tail light guard.....
are you refering to this?Craig said:I just have a small wheel mounted to the side of mine, well I think thats what it is for......![]()
I see....its the same thing craig, a harmonic damper for the front diff. It dampens harmonic vibrations created by the rotoflex I believe.......some people take it off once they go U-joints.Craig said:Its similar mate but mine is just a single wheel and is flush with the bottom of the axle (maybe slightly past it, say 10mm) So whats it for!!!!
hmm.....perhaps it only helps if you break/wear out your rotoflex?.....I wonder if it has something to do with the rotoflex....though that picture craig shows has a u-joint on the end...hmmroverX said:Man, my harmonic balancer is all bent to ****...and there is no difference in how she handles or runs...
