Axles
Drum665
Are you planning on going to lockers, if so with that large a tire, you should consider HD axles. I had a friend last summer, took out his rear axles and front case do to the light dutyness of them.
Also consider the BFG MT's instead of the AT's, much better tire both on and off the road.
One last thought, gears, if all that tire you will be loosing some power, may want to consider 4:11's especialy if you are going to get serious off the road. By the way 4:11's will alsao help your gas mileage also.
Good luck,
Mike J.
