After seeing many Discovery 1's advertised for sale with rear windows not functioning, I thought it was a fairly common issue (even though my '96 has never had a problem). The fronts on this newly acquired SE7 (less than a week) work fine but neither rear window does anything, no up/down/sounds/clicks/motion/anything etc, suggesting an electrical issue somewhere common to a harness or relay etc. I find it illogical for the rears to malfunction when the fronts work fine unless a previous owner had some odd behaviors and used the rears more, or, as stated, there are common issues with Disco 1's rear windows. I kinda doubted switches as the issue, (both rears not working at all?) and eliminated the lockout switch on the window panel by jumpering it. Also kinda doubted both rears would have malfunctions within the doors (switches or motors etc) although I suppose that is a miniscule possibility.
Your suggestions have most likely covered it and have prevented much searching. Many thanks! I'll get on it this weekend......just hope for no rain as one window is stuck down about 6"......
