well, I changed my plugs, wires, dist cap and rotor. Ran fine, no problems. Then I noticed that I had not put on the new coil wire the next day. Oh, well, so I change it out. Runs fine, no problem. Then the next day, my battery icon light stays on. Book says it is an ignition problem light. Coincidence in timing that it came on 2 dyas after plugs, etc changed? I went back and double checked all my connections, pulled the cap off, re-seated the rotor, put cap on, triple checked connections, switched coil wire back to old one, to see if new one was bad, no change. ?? Any ideas? :dunno:
It was also 'surging' - after I checked everything and started it back up, surge was gone...???
