1 - 4 of 4 Posts
I want to replace the battery in my 2000 D2, but am concerned about what's going to have to be reset. I know the radio will have to be programmed, but what else can I expect. Th :drive: ank you
Well,
if you want , there is a kit you can buy in the auto store. It is a battery pack made of several AAs and plug into the cigarette lighter. It feeds 12v into the system, swap out your battery, and it will be as if nothing was disconnected.
Ask for it and use fresh batterys. :drive:
or get this instead
https://www.safehomeproducts.com/SHP/SM/12V_Power_Products.asp#AutoJumper
Coleman and Radio Shack sells it too. Check your local Walmart or Big Box store with camping section and an auto section.
Radio code and reprogramming the radio channels, that's all.
Mike J.
1 - 4 of 4 Posts
