replacing an indicator unit (£3 odd) turned into a voyage of discovery that:-
(a) the headlamp backing bowl was rusted to bits
(b) the bolts that didn't shear off were unusable
(c) Local B&Q 4mm bolts and locknuts attached the indicator mount and 5mm bolts and lock nuts re-attached the headlamp bowl (temporarily)
(d) the wiring loom fixing bracket (that doesn't use the backing bowl bolts to anchor) needs a replacement (large hex bolt and nut)
(e) and last but not least, I attempted to undo the wiring loom fixing bracket in the engine bay (incorrectly) and it remained intact as I turned it but now i have a penny size hole in my wing...
so, any recomendations for stainless steel bolts/locknuts (reasonable rather than B&Q inflated prices) that are in the 4, 5, 6, 7mm etc range?
Thanks
Simon
"it'll only take 20 minutes - honestly darling!"
Thanks
Simon
