1 - 7 of 7 Posts
· Premium Member
i want to put 32" BFG all terrains on my stock wheels....what size tire would i need to purchase?
· Wheeler
Well, that depends on the size of your stock wheels,,,which will vary by model.
On a DII, you can run 265/75/16, which is about a 31" in BFG,,,, or a 285/75/16 which is about a 33", perhaps a hair under. Just make sure you have the right lift & clearance or you'll get rubbing & have stuffing problems. Either way you'll have some rubbing on radius arms at full turn. To properly run 285's off-road you'll need at least 3" of lift on a DII.
DIs are a bit different, perhaps someone can comment but the 265's don't seem to be a very good fit. I can't remember the right metric size, someone here will step in.
If you have 15" wheels you can simply find a 32" tire in a width appropriate to your wheel.
· Premium Member
Discussion Starter · #4 ·
well i am planning on a 2" lift, but all the OME stuff says it is only a 1.5" lift. any suggestions here. i want at least 2 and 3 would be fine as long as it only requires springs and shocks!
· Wheeler
Sorry, I failed to see your footer,,where you indicated a DII.
I'm not as familiar w/ OME as some on this board, but I know they make an HD spring with 2" of lift. Perhaps another member can adv. the model #. You can run 265's on a DII w/ a 2" OME lift, no problem. And no need for any other modifications (stock brake lines, ABS lines, etc)
· Premium Member
Discussion Starter · #6 ·
can i get a 3" lift without any further mods...and if so, what type of springs are good?
· Member
Go with the OME 3" lift, which you can read about on the expeditionexchange.com OME section.. costs about $700 with shipping I think.. no additional mods needed.. the 265/75/16s fit fine with this..
That's what I'm running, with trXus' 265/75/16 (about 31.9x10.6)
1 - 7 of 7 Posts
