The other day I was stuck in park and used a paper clip to by-pass the brake switch until replacement arrived.
When I replaced the brake switch I was still unable to shift out of park. I check the fuse under the dash for the brake lights and it was bad. I replaced and everything worked fine for about a day or less.
Now I am blowing the brake light fuse, under the dash, almost every time I start the car.
Any suggestion would be helpful and if you feel it is a short is there a most likely location or am I destined to be searching forever?
Thank you.
Don :dunno:
Thank you.
Don :dunno:
