Running the engine at idle from cold with the rad cap off you should see a constant steady stream flowing into the expansion tank from that hose. If you do not it may be clogged.
If you want to blow it out to ensure it is clear, disconnect it at the drivers side top corner of the radiator and blow through it.
Hope that explaines it
