I have had an anti-lock light on for sometime.
The code that it throws is the brake switch which I have replaced. The code would not clear and the lights have been on ever since. I recently had to replace my accumulator due to the fact that the ABS pump would not shut off. I replaced the relay also. I managed to get the system working properly again on Halloween night.
Today on the way in to work I had to jam on the brakes.
And when I got to work 15 minutes later I shut off the engine and the ABS pump was still running. I know that they are not supposed to run constantly. And I know they will burn up if they do run constantly.
What is going on with this thing!???
Has anyone had any experience with the brake system?
