1 - 7 of 7 Posts
Discussion Starter #1
My 94 Range is in dire need of brake work. The front hard lines that go to the calipers are extremely rusty and I can't believe that haven't blown out. The pedal is also soft. The ABS also doesn't work so....I'm thinking of changing things up.
I want to get rid of all the ABS equipment and possibly the master cylinder. It would be easy enough to use a booster/master from a jeep Cherokee or similar.
Has anyone on here modified the brake system on a classic? Is there an easy brake swap that I'm overlooking? Disco/defender/non abs classic?
Rover-Holic and Admin
Order the booster and master cylinder for a Range Rover Classic Hunter edition. It had no abs and will bolt straight in. Might have to adjust a few hard lines but that’s it.
Excellent choice if you can find a center console out of a 87-88 RRC it is set up for the LT230 shifter. Rare as hens teeth though anymore.
1 - 7 of 7 Posts
